I tried it multiple times. Didn't help. It only ruined my MSI AB graph with spikes caused by Alt+Tab'ing.Whack everything on full settings, load up gtav get ingame, alt tab out then go back into the game, see if that helps
Still confused. So, on MIN settings GPU stays in idle but CPU produce graphics and physics itself only?At such low resolution The CPU is under high load because it can't keep the GPU supplied fast enough.
AT 800*600 your 1080Ti is basically doing nothing.
Got it. Thanks.The GPU always produces the graphics. On low resolutions the GPU can draw the frame quicker than the CPU can send it, so it's waiting for the CPU all the time. At higher resolutions, it takes longer and longer for the GPU to draw the frame so the CPU doesn't have to work as hard, as it's waiting for the GPU to finish before sending the next frame.
Will try.Set up your AB like this and see what's causing the bottleneck:
https://forums.overclockers.co.uk/threads/how-to-tell-if-theres-a-bottleneck.18799039/
UPDATE 2:
LatencyMon during game without FPS cap: https://drive.google.com/drive/folders/1gim1F9ypbhXzjr4GxSER56b_rapZBDaO?usp=sharing
But it hadn't the highest ISR latency. So, what is 20x on your system? 20 ms?HDAudBus.sys is generating a ridiculously large number of ISRs (more than 20x as many as my system over a similar period)... I reckon it's your audio drivers.
I divided my 236 GB SSD onto 2 partions, 1 OS - 102 GB (~35 gb used), 2 SSD Games - 134 GB (~70 GB used (Witcher - 33 GB, WOT - 32.6 GB, tools ~4 GB)). Totally: ~105 GB (45%) used from 236 GB available.Boot SSD drive... do you have at least 30% of drive free?
Thanks for reply. Got it.On my older build a few years ago (which ran SLI), I had to keep a log of personal game fixes to combat stuttering in all sorts of different ways. I became quite obsessed about fixing stutter in games. It wasn't just an SLI issue either, by the way.
On my newer rig (1080Ti, x99 and 5930k on x34 Gsync monitor) I now have very few stutter issues in games, and the few that do can usually be sorted with a simple frame rate capping using RTSS, usually 1 frame below monitor refresh rate. Assassins Creed Origins is a prime example of this. Micro Stutters and pauses like a bitch, unless I cap frames 1 under refresh rate. The difference is remarkable i.e. almost zero stutters using this simple fix.
I know this doesn't help the OP though and I've Not read through all this thread yet, so apologies if this has been mentioned, but I also found a main cause of stutter in some games was the CPU setup in the bios and the power states settings. To cut a very long story short I like my CPU to run at minimal speeds and low volts when idle, but obviously ramp up as necessary when gaming. I found that getting my CPU to ramp up to constant max clocks in games though was hit and miss and it would often fluctuate and clock down, which causes stutter in some games.
To combat this you can obviously set the windows power plan to "High performance", but then you have to turn it off / back to balanced manually if you want everything to clock back down. I found an amazing free little (old!) utility a while ago that does it for you automatically, on a game by game exe basis - called Full Throttle Override http://tringi.trimcore.cz/full_throttle_override?language=en
I add every game exe to this little prog now, just to be sure.
Also, may have been mentioned already, but have you seen this about certain Windows 10 creators update and stutter. Something to do with a standby memory issue. Not tried it myself as don't feel the need, but lots of people reporting v good stutter fix for some games...
https://forums.guru3d.com/threads/how-to-fix-game-stutter-on-windows-10-creators-update.420251/
UPDATE 3:Boot SSD drive... do you have at least 30% of drive free?
I tried to test games on both drives, M.2 SSD and HDD. No changes.disable all audio drivers in device manager also run no overclock program in the background, delete all GPU drivers, install only the GPU driver itself nothing else
go into the bios disable anything you dont use
see how that goes, I also got this issue when a game on my HDD was failing so try a diffeent drive if you can.
All games I've tested. Almost no issues in WOT but it's only 1 game. I'll test more games.I feel your pain. Something like this is infuriating, and it's easy to get obsessed, and be over obsessive about it.
Talking of, is it only these 2 or 3 specific games that are having specific issues, or is it all games???
