1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Need Your Help! FPS Drops & Stuttering on High-End PC
Discussion in 'Graphics Cards' started by Knower, Apr 8, 2018.
  1. Knower
    Sad to hear.
    1. Is your TW3 stuttering issue absolutely the same on RTX 2080 Ti as the stuttering on 1080 Ti? Or are there any key differences/improvements with 2080 Ti?
    2. What about PUBG? Some improvements with 2080 Ti?
    3. Did you try Intelligent standby list cleaner (ISLC)
    I saw a bunch of people swearing that ISLC fixed all the stuttering. I don't know is that a truth but will try later.
    4. Did you try new Win10 1809 build? Any advantages over older 1803?
    5. What about Win10 LTSB 1607 or LTSC 1809?
    Thank you for the info!
  2. ltron
    Wise Guy
    1. The stuttering was actually worse on the 2080Ti in The Witcher 3
    2. I don't play or own PUBG
    3. I haven't tried this, clearing the standby list only helped when it was full anyway.
    4. I am on 1809 now and there are no improvements.
    5. I haven't tried these and don't think I should have to go so far to fix the issue, I'd rather get an AMD card instead.
  3. Knower
    Dang.
    I'm so disappointed about these issues on such a good HW.
    1. What's your edition and DRM of TW3? Steam or GOG?
    2. AFAIK, standby list gets rapidly full when running games like PUBG or Battlefield 1.
    And I saw a few posts on tech forums that 16 GB RAM isn't enough to work around this Windows memory bug. And someone well know (maybe it was Wagnard (DDU developer)) said that stuttering will go after adding extra 16 GB of RAM, totally 32 GB will be enough to almost eliminate frametime spikes, as Wagnard said. But I can't imagine that 32 GB will magically fix something. I doubt so, but who knows...
    3. Are there any critical bugs on 1809? Is it worth to upgrade? Also I saw some videos about increased frame rate on 1809, but again, I doubt.
    4. Unfortunately, there are no one competitive AMD GPU to match even 1080 NVIDIA card.
  4. ltron
    Wise Guy
    1. I have both the Steam and GOG versions, there is no difference.
    2. I have 32GB of RAM, but my standby list can still get full, after a big update to BF1 for example or playing many different games in one session.
    3. Not as far as I know. Frame rate is around the same, maybe slightly lower in some games.
    4. A Vega64 is significantly faster than a 1080 in some games such as Forza Horizon 4 and BF V. An undervolted and overclocked Vega is faster than a factory overclocked 1080 even approaching a 1080 Ti in some games. However, it is pretty much a side grade from a 1080 overall. Maybe next year AMD will have something great for us.
  5. klaxhu
    Gangster
    Now I haven't read every detail of this thread but I have also tried several things from here before I tried the video above and still no change.
    And the I tried this and it worked: https://www.youtube.com/watch?v=alJ5A0AK1e4
