- 5 Sep 2005
- Northern Ireland
Right, I have a Netgear FWG114P VPN router. Its working fine. Can't fault it whatsoever. I also have the Netgear Prosafe VPN client software.
After pulling my hair out quite unsuccessfully for several hours, I give up....I can't figure out how to get the VPN to work. Every guide I do to is filled with acronyms and abbreviations, reads like the alphabet jumbled up, and generally makes no sense.
Now....for what I can make out I need to get some "Certificate Authority" to issue me with a certificate, which I then add to the Prosafe software, which will give me access to the Routers network (if I get the router configuration correct) .
Simply put what on earth is a Certificate Authority? Its just a small home network that I want VPN access to, do I need some other piece of software? Do I need to set up a server in some way? Can the router act as the certificate Authority?
I was asking on the Netgear forums, and all the help they would give me was a bunch of .pdf documents, which didnt really help.
So.....does anyone here have a Netgear VPN router, and can they give me a little help in getting my router to accept VPN connections? Any help or advice at all would be great, so if you think you have something to add, please type it in!
Cheers!
Cheers!
