Hi,
I've a 1999 Skoda Octavia 1.9TDI. It is starting to struggle to crank over first thing in the morning and after being left all day before I travel home from work when it's been cold.
It currently has a 075 type battery with a 540 CCA (I think, if I recall correctly) I've been trawling the web and it seems a higher CCA battery, an 096, may be a better bet?
Would this be correct?
And can anyone recommend a decent battery replacement that doesn’t require a 2nd mortgage to buy
Thanks.
Thanks.
