New Build Gainward GTX 680 Problems :( HELP!
8??! Nice...
In your bios under memory setting or whatever, set the Command Rate (CR) to 2T rather than 1T you have it set to in that screenshot. A bit slower but stable by all accounts.
Update:
Since changing the ram timing to 9-9-9-24 and putting all the sticks in, it looks to be stable and also went through benchmarks fine!!
I do have another question regarding the ram though... Why does it only say 16GB usuable? Does win7 only support 16gb?
Cheers guys!
I believe windows 7 versions will read ram differently. Maybe 32bit will only read 16gig or the basic edition will, without looking it up I can't remember which does which off the top of my head.
Glad it is stable anyway and fingers crossed it remains this way :)
Update:
Cheers guys!
If it's Windows Home Premium x64 then yes. You need Win7x64 Professional, Enterprise or Ultimate to support more.
its x64 Home Premium. Guess that answers my question, i'll buy an upgrade later :)
Thanks for your help throughout guys, hopefully this may solve a few issues in due course for others!
