- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
*** *** Coolermaster Silent Pro Modular 850W Power Supply @ £129.98 inc VAT *** ***
Cooler Master adds the M850 to the Silent Pro series, giving extreme overclockers and/or ultra high-end systems all the power they need. With up to 80A on a single 12V rail, these power supplies deliver where it counts and won’t have any problems powering even the most demanding multi-graphic card systems. These units feature flat modular cables for improved airflow and cable management. It also comes with shock absorption silicon pads to remove possible vibrations.
- Copper plus aluminum heatsink for efficient heat dissipation.
- 135mm ulta silent fan.
- Japanese-made capacitors to enhance PSU outputs stability.
- Compliance with the newest Intel standard ATX 12V V 2.3 and SSI standard EPS 12V V2.92.
- Flat modularized cables to eliminate the clutter and improve airflow inside the chassis.
- Ultra-silent operation with intelligent 135mm fan speed control.
- Unique silicon pad eliminate the vibration.
- Eco-design for energy and money saving by Active PFC.(>0.99) / high efficiency (>85%).
- Single +12V rail for up to 80A for high demanding SLI.
- 5 Year Warranty
Only £129.98 inc VAT.
ORDER NOW
- 5 Year Warranty
ORDER NOW
