New Corsair GS Gaming Series Power Supplies!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys,
The new GS series PSU's from Corsair have landed and are available to order now. With 80 Plus certification and highly reliable these gaming PSUs with 3 colour LED lighting system is ideal for any avid gamer.
Corsair Gaming Series GS 600W 80 Plus Power Supply @ £69.98 inc VAT
The Corsair Gaming Series GS600 power supply is the ideal price-performance solution for building or upgrading a Gaming PC. A single +12V rail provides up to 48A of reliable, continuous power for multi-core gaming PCs with multiple graphics cards. The ultra-quiet, dual ball-bearing fan automatically adjusts its speed according to temperature, so it will never intrude on your music and games. Blue LEDs bathe the transparent fan blades in a cool glow. Not feeling blue? You can turn off the lighting with the press of a button.
- It supports the latest ATX12V v2.3 standard and is backward compatible with ATX12V 2.2 and ATX12V 2.01 systems
- An ultra-quiet 140mm double ball-bearing fan delivers excellent airflow at an exceptionally low noise level by varying fan speed in response to temperature
- 80Plus certified to deliver 80% efficiency or higher at normal load conditions (20% to 100% load)
- 0.99 Active Power Factor Correction provides clean and reliable power
- Universal AC input from 90~264V — no more hassle of flipping that tiny red switch to select the voltage input!
- Extra long fully-sleeved cables support full tower chassis
- A three year warranty and lifetime access to Corsair’s legendary technical support and customer service
- Over Current/Voltage/Power Protection, Under Voltage Protection and Short Circuit Protection provide complete component safety
- Dimensions: 150mm(W) x 86mm(H) x 160mm(L)
- MTBF: 100,000 hours
- Safety Approvals: UL, CUL, CE, CB, FCC Class B, TÜV, CCC, C-tick
Only £69.98 inc VAT.
ORDER NOW
Corsair Gaming series GS 700W 80 Plus Power Supply @ £79.99 inc VAT
The Corsair Gaming Series GS700 power supply is the ideal price-performance solution for building or upgrading a Gaming PC. A single +12V rail provides up to 56A of reliable, continuous power for multi-core gaming PCs with multiple graphics cards. The ultra-quiet, dual ball-bearing fan automatically adjusts its speed according to temperature, so it will never intrude on your music and games.
Tri-color LEDs illuminate the transparent fan blades at your command. Choose red, white or blue for the appropriate dramatic effect, or turn them off entirely at the press of a button.
Only £79.99 inc VAT.
ORDER NOW
Corsair Gaming Series GS 800W 80 Plus Power Supply @ £94.99 inc VAT
The Corsair Gaming Series GS800 power supply is the ideal price-performance solution for building or upgrading a Gaming PC. A single +12V rail provides up to 65A of reliable, continuous power for multi-core gaming PCs with multiple graphics cards. The ultra-quiet, dual ball-bearing fan automatically adjusts its speed according to temperature, so it will never intrude on your music and games.
Only £94.99 inc VAT.
ORDER NOW
