** NEW IMPROVED EVGA 970's ARE ON THEIR WAY!!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
EVGA new 970's with improved heatsinks for upto 5c better cooling amongst other new features and finally a backplate on the FTW+ card.
Arriving next week at OcUK:
EVGA GeForce GTX 970 SSC rev2.00 ACX 2.0 4096MB GDDR5 PCI-Express Graphics Card (04G-P4-3975-KR) @ £299.99 inc VAT
The new NVIDIA GeForce GTX 980/970 is powered by the next generation NVIDIA Maxwell Architecture, giving you incredible performance, unmatched power efficiency, and cutting-edge features.
Maxwell is the most advanced GPU architecture ever made, designed to be the engine of next generation gaming. Inspired by light, it was designed to solve some of the most complex lighting and graphics challenges in visual computing. For the first time, gaming GPU's can dynamically render indirect light using the new VXGI (Voxel Global Illumination technology). Scenes are significantly more lifelike as light interacts more realistically in the game environment.
The GTX 980 is the worlds fastest GPU and the GTX 970 offers the most advanced performance in its class. Each delivers 2x the performance of previous-generation card, bringing new gaming experiences to virtual reality, and ultra resolution 4k displays.
Enable the detail of 4k monitors, on a 1080P display. DSR produces smoother images by rendering a game at a high resolution, then downscaling it to the native resolution of the display using advanced filtering.
GeForce GTX 980 and 970 cards support tear-free, super-fast NVIDIA G-Sync monitor display technology including 4k. Together, these technologies provide the most immersive and competitive gaming experiences possible.
Features:-
- dBi – dB Noise Inverter turns fans off below 60C, generating 0dB of noise during idle!
- QSD BIOS – Quick Switch Dual BIOS allow you to switch to secondary BIOS with the flick of a switch.
- MMCP – Memory MOSFET Cooling Plate reduces MOSFET temps by 47% and Memory by 14%.
- OPT – Optimized Power Target offers 33% more power over reference.
- SHP – Straight Heat Pipes reduce GPU temperature by almost 5C!
- EVGA ACX 2.0 Cooling: With optimized swept fan blades, double ball bearing and an extreme low power motor, EVGA ACX 2.0 delivers more airflow with less power, unlocking additional power for the GPU.
- Voxel Global Illumination Technology (VXGI)
- NVIDIA® Super Resolution technology
- NVIDIA® GameWorks technology
- NVIDIA® GameStream technology
- NVIDIA® TXAA Technology
- NVIDIA GPU Boost 2.0
- NVIDIA PhysX® Technology
- NVIDIA FXAA Technology
- NVIDIA Adaptive Vertical Sync
- NVIDIA Surround
- Support for four concurrent displays including: Two dual-link DVI, HDMI and DisplayPort 1.2
- Microsoft DirectX 12
- NVIDIA® 3D Vision® Ready
- NVIDIA SLI® Ready Technology
- NVIDIA CUDA® technology
- PCI Express 3.0 support
- OpenGL 4.4 support
- OpenCL support
- NVIDIA SHIELD Ready
- NVIDIA G-Sync Ready
Specification:-
- GeForce GTX 970
- GPU: GeForce GTX 970 (GM204)
- Core Base Clock: 1190MHz
- Core Boost Clock: 1342MHz
- Memory Clock: 7010MHz
- Memory Size: 4096MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 256-bit
- CUDA Cores: 1664
- DirectX 12: Yes
- DVI Port: 2x Dual-Link DVI, 1x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 3yr
Only £299.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 970 FTW "Plus Edition" ACX 2.0 4096MB GDDR5 PCI-Express Graphics Card (04G-P4-3978-KR) @ £319.99 inc VAT
Features:-
- Backplate!
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 970
- Core Base Clock: 1216MHz
- Core Boost Clock: 1367MHz
- CUDA Cores: 1664
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 450W PSU Required
- 150W TDP
- Warranty: 3yr
Only £319.99 inc VAT.
ORDER NOW
We can only hope they have .. but I am sure it would be in the details if they had improved it chance to not be ?.
If they do have coil whine what is the deal with them .. Can you return ? I need a new card for a new build .. I have the Superflower platinum 1000W psu so have a good start / recommended PSU . but if I get one and it's got coil whine?
Richard
Have EVGA quietly done something with this to reduce coil whine?
They have inserted a metal plate which covers all the inductors, memory chips etc and in theory this will help dampen any vibrations the inductors might give but the plate is not designed as such to reduce whine but it could have that kind of positive side effect. :)
In our factory the lab found the best effect was changing the containers to a higher spec and then using glue on them, and they did spend a couple of weeks trying different techniques to finally come to this and the design changes found most effective were implemented into our KGA2 Infinity Black Edition. :)
Which 970s do have the coil whine or is it just down to luck?
Its more luck, some cards don't do it at all but at the same time you can have a completely silent card in one PC and then put it in another PC and it will scream.
All manufacturers can do is try to find ways to reduce is because by employing such methods then the outcome will be your luck improves. :)
In all fairness, the price from EVGA is practically the same but the exchange rates have crashed and the GBP is very weak now so the cards now cost us over £10 more landed simply due to GBP weakening. :(
I don't follow the market,but you seem to be right. Wow the pound is weak? I've never seen the pound this weak :(
Predited to get even weaker......
Surprised no one has commented on the forums to be honest, GTX 980's got as cheap as £360 before XMAS and 970's for £240, now your lucking at a massive chunk more on those alone and remember the dollar pretty much effects every product in the IT industry........
Gibbo what about the tech lab 970 watercooled cards any coil whine on them?
Nope.
Coilwhine reduction can only be done at the factory, we do not fancy trying to solder cards or glue down inductors by hand, would cause massive issues.
So a Techlab card is literally just the waterblock, but of course some of the Techlab cards are based on the Infinity card which have the reduction technology.
