Hi all, just looking for opinions and advice on my new setup which im slowly building.
so far its Q6600 processor, 4 gb of pc6400 ram, Gigabyte GA-965P-DQ6. I have just ordered 2 WD 36gb raptors (16mb cache ncq) in RAID 0 and intend to install the OS (win xp 64bit) onto them, then create a partition just for the swap file (64k cluster size, bigger is fastest ryt?).
For cooling i intend to use a 550watt peltier for the cpu and a 90watt one for the Nbridge, on top of the cpu and pelt im gonna put the thermaltake volcano 4005 and situate my radiator outside on my roof, the pump ill be using is a eheim and pumps 10 liters per min.
The PC will mainly be used for rendering 3D work, photoshop, maya, 3d max etc.
Any advise or suggestions please as im new to the cool side
Cheers.
Cheers.
im thinking finely tuned tripple cascade phaze would struggle to cool that one effectively... may want a bit of a re-think...
