Phanteks Enthoo Evolv Micro ATX Case - Black @ £99.95 inc VAT
Enthoo EVOLV, an mATX/mITX chassis, sports a beautiful all aluminum exterior. The EVOLV’s unparalleled design features an all new tool free release system for the outer panels. The EVOLV supports many high end PC components while maintaining a minimalist design.
Functionalities:-
- 1x Drop-N-Lock SSD brackets included
- Multifunctional Side Bracket - (mounting for 2x SSD’s / 1x HDD)
- Removable HDD cage for installation of long PSU’s (>180mm) / waterpump
- Equiped with removable dustfilters (1x front, 1x bottom, top integrated)
- Phanteks’ PWM hub included
- Clean cable management
- Phanteks’ pre-installed Hoop-N-Loop cable ties
- Quick release panels for easy acces to fans and dustfilters
- Toolless sidepanel with swing door
Aircooling:-
- Optimal airflow - Direct airflow to CPU / GPU
- Comes with 2 Phanteks premium fans 1x PH-F200SP in front (200mm) 1x PH-F140SP in rear (140mm)
Watercooling:-
- 3 different installation areas for single or dual radiators (120mm and 140mm form factor).
- Reservoir mounting points on the Side Bracket
- Pump Bracket with vibration dampers - Mounted on Side Bracket/ HDD base
Specifications:-
- Dimension 230 mm x 450 mm x 400 mm (W x H x D)
- Form Factor Micro tower
- Material(s) Aluminum exterior, Steel chassis
- Motherboard support uATX, mITX
- I/O (side) 2x USB 3.0, Mic, Headphone
- Side window Yes
- Expansion slots 4
- External 5.25” 1 (modular)
- Internal 3.5” 3
- Internal 2.5” 5 (1 slot for upgrade)
Clearance:-
- Graphic card 318 mm
- CPU cooler 192 mm
- PSU 216 mm
- (remove Midplate cover for PSU longer than 180mm)
- Cable management 24 mm (216 mm below midplate)
- Radiator (TOP) 68 mm to motherboard (offset)
Only £99.95 inc VAT.
ORDER NOW
Phanteks Enthoo Evolv Micro ATX Case - White @ £99.95 inc VAT
Functionalities:-
Aircooling:-
Watercooling:-
Specifications:-
- Side window Yes
- Expansion slots 4
- Internal 3.5” 3
Clearance:-
- CPU cooler 192 mm
- PSU 216 mm
ORDER NOW
Functionalities:-
Aircooling:-
Watercooling:-
Specifications:-
- Side window Yes
- Expansion slots 4
- Internal 3.5” 3
Clearance:-
- CPU cooler 192 mm
- PSU 216 mm
ORDER NOW
Functionalities:-
Aircooling:-
Watercooling:-
Specifications:-
- Side window Yes
- Expansion slots 4
- Internal 3.5” 3
Clearance:-
- CPU cooler 192 mm
- PSU 216 mm
ORDER NOW
