*** New Product for Pre Order In-Win 703 and 707 ATX tower cases.***
7 Feb 2011
Stoke on Toast
After In-Wins last two launches it's nice to bring you a good looking offering at a more desirable price point.
In-Win 703 Midi Tower - Black / Red @ £47.99 inc VAT
703 mid tower
The 703 is ideal for smaller pc builds that still require an ATX motherboard. Both black and white versions feature the large side-panel window, to proudly display your pc build inside.
Constructed using the same steel as the 707, the 703 offers a similar, stealthy 5.25-inch external drive bay with two more inside and four internal, tool-less 3.5-inch HDD bays. Designed primarily for heatsinks or all-in-one liquid cooling, it has an ample 170mm depth to the acrylic window opposite for tall heatsinks, cable routing holes and large heatsink installation hole in the motherboard tray.
Extreme simplicity and classic design
- Transparent acrylic side window panel
- Aluminium hairline textured panel
- Dual colour with succinct shape
- Red led fan to provide visual effects
Excellent expandability
- Seven PCI-E slots to support high-end full size graphic cards up to 408mm / 16.1"
- supports CPU heatsink up to 170mm/6.7"
User friendly
- Easy installation of CPU cooler via a retaining hole without removing motherboard
- Easy removable anti-dust filter for fan and power supply odd tool-less design
Specifications:-
- Form Factor: ATX, M-ATX
- I/O Expansions: USB 3.0 X 1, USB 2.0 x 2
- Fans
- Rear - 120mm Red LED Fan x 1 (Included)
- Front - 120mm Fan X 1 (Included)
- CPU Heatsink upto 170mm/6.7"
- Drive Bays
- 5.25 1 x External and 2 x Internal
- 3.5" 2.5" 4 (Supports up to SATA HDD EZ-Swap Module x 4) 2.5" x 2
- Power Supply ATX 12V, PSII Size and EPS up to 220mm (170mm with Bottom Fan)
Only £47.99 inc VAT.
ORDER NOW
In-Win 707 Full Tower - Black / Red @ £79.99 inc VAT
707 Gaming Black and Silent White feature sleek brushed aluminum finish front panel with smart optical
drive door design. Superior and versatile cooling options with perforated top panel allow quick heat
dissipation.
Specifications:-
Case Size: Full Tower
Case Material: Steel
External Drive Bay: 5.25" X 3
Internal Drive Bay 3.5" X 8
Motherboard Form Factor E-ATX ATX M-ATX
Power Supply ATX 12V upto 220mm
I/O Front Panel USB 3.0 x 2, USB 2.0 x 2 HD Audio
I/O Expansion Slots 8 x PCI
Thermal Solutions:
Air Cooling:-
- Front 140m X 2
- Rear 140mm Fan X 1
- Side 120 or 140mm Fan X 1
- Top 120mm X 3
- HDD Cage 120mm or 140mm X 1
Water cooling:-
- Top 360mm Radiator Support
- Bottom 240mm Radiator Support
CPU Heatsink: Cooler height upto 206mm
Dimension: 532 x 243 x 582mm
Weight 11.4 kg
Only £79.99 inc VAT.
ORDER NOW
Nice looking cases, quite like the compact looking Midi tower, though I do with there was a Black/Blue version (would go better with my system!).
edit: not quite sure why the Midi case has two internal 5.25" bays - seem a bit useless to me? would rather have more space or more 2.5/3.5 bays
That 703 looks like it could be perfect for a build a friend wants done at the end of November. Any idea on likely timescale for it to be in stock?
