Right, i think im almost there. Do i need a backplate for the 1080ti? Nothing in stock at the moment. Should i get a 360 radiator instead of a 280?
My basket at Overclockers UK:
- 1 x EK Water Blocks EK-KIT P360 Performance Watercooling Kit= £299.99
- 4 x EK Water Blocks EK-ACF Fitting 10/13mm - Nickel= £4.99
- 1 x EK Water Blocks EK-CoolStream CE 280 (Dual)= £71.99
- 1 x EK Water Blocks EK-Duraclear Tubing 13/10 - Clear 3M= £12.95
- 1 x Mayhems Dye Orange 15ml= £4.99
- 1 x Mayhems Ultra Pure H2O 5Ltr= £13.99
- 1 x EK Water Blocks EK-Cable Y-Splitter 3-Fan PWM (10cm)= £2.99
- 1 x XSPC LCD Temperature Sensor (Blue) V2 + G1/4" Plug Sensor= £6.95
- 1 x EK Water Blocks EK-AF Ball Valve (10mm) G14 - Nickel= £14.99
- 1 x Mayhems Fine Silver Kill Coil= £3.95
- 1 x EK Water Blocks EK-FC Titan X Pascal / 1080 Ti - Plexi= £94.99
Ha, thats so cool! and what they guesstimated is pretty much what i have on order!
I did my first custom loop (CPU + GPU) about 6 months ago, and had no issues. Just take your time, and don't rush into it...
I would however recommend ordering a couple of extra rotary fittings just in case you need them. I ended up using a couple more 45° ones instead of the 90° ones.
what type of rotary fitting what i need with the current kit im ordering? there are loads!
so if the fittings on the 360 loop are nickel am i OK to get a copper waterblock for the 1080ti...
