Man of Honour
Thanks! but i guess the backplate which is in stock "backplate made from black anodized aluminum" is a no no..
The backplate is fine as it is not in contact with water
That makes perfect sense! thanks. Wait is that £5.99 for 1... lol
also, may i ask what light you're using?
Those fans are really poor. Not much use for radiators.Yeah so my case already comes with corsair Air Series AF140L fans.
https://www.overclockers.co.uk/cors...-quiet-edition-co-9050017-wled-fg-030-cs.html
Do you think i need better fans for the radiator?
oh.... guess im making another basket! what do you recommend? the link you added didnt work.
Sorry link was for something elseoh.... guess im making another basket! what do you recommend? the link you added didnt work.
It's about a thickness If you're changing to 240 you can change to PE (it's 40mm thick). Then I believe there are cheaper fans 120 EK vardar, like you have in your EK kit.Actually i think its wise if i swap the 280 to a 240... just to be safe..
or
https://www.overclockers.co.uk/alpenfoehn-140mm-wing-boost-2-plus-pwm-fan-fg-010-al.html
from what i can tell there are the same spec? except one is more expensive
