Well Android is outselling iphones so statistically this is an Android forum if you go by how many users of each make up the forum.
MW
MW
If you want a full 4-5 days of web browsing/gaming/sat naving/movie watching on a hi-res 3.5"+ screen then you'll be waiting a long, long time
Get a spare battery for peace of mind.
HTC Hd2 with Android 2.2 on it.
You think that is the next best thing to an iPhone?
cos it's annoying, my e72 used to last 4-5 days without having to charge it. People are more worried about dual cores than decent battery longevity
just got a san francisco and the battery life is so badhaving to charge it daily is annoying.
seems like a bit of a random choice tbh
Couldnt go back to apple after moving to a desire, so much more customisable, faster, more features, cheaper, more updates, more apps, you can run a lot of apple apps on the desire now.
the battery on my SF lasts 2 or 3 days when the wifi/3g is off. on it lasts a day and a half with quite a lot of use.
Can the desire run nanostudio? If so is it easy to do?
Each to their own, you can load your own fart samples into Nanostudio if you really want to get creative!2.3 adds scope for low latency but it really depends on the phone/tablet manufacture. A minimum spec of 45ms might be enough to temp some devs? Best stick to Apple until a there's loads of guaranteed high end devices around to target.
...and I'm sure most people will find fart apps just as useful as nanostudio![]()
Hi, music software has come a long way over the last few decades, and to have something as powerful as Nanostudio running on something that you can fit in your pocket is a godsend, weather you are a professional musician or simply make music for fun... Simply because you can do it on the train, bus, etc... I'd rather make a few tunes instead of playing Angry Birds over and over...I had to look up nanostudio, but it seems to be one of those 'Everyone's a DJ and record producer' applications that seem to have sprouted up over the last 10 years as digital recording has been made easy. On the whole I'd say fart apps are probably more of a productive use of time for most people.![]()
I can't justify spending so much on an iPhone, so what's the next best thing in terms of quality and functionality?
Thanks.
