- 1 Sep 2005
- Scottish Highlands
Im looking at getting a bit more kit for my new D40x to allow me to get some better(read closer) macro shots. Im on quite a tight budget here, so im investigating the option of extension tubes, diopters, lens reversal adapters etc etc. Has anyone got much experience with any of these? Any comments or tips?
I think ive ruled out the idea of reversal adapters, because as far as I can tell you have to really play around with setting the aperture before fixing the lens etc, and it would definately rule out AF, and possibly mess with metering etc.
The next option is extension tubes or teleconverters. Im thinking this is probably the best option. So far I have seen;
Nikon TC-20E II 2x AF-S, AF-I Teleconverter ~£230
Nikon TC-17E II (1.7x) AF-S, AF-I Teleconverter ~£260
Nikon TC-14E II 1.4x AF-S, AF-I Teleconverter ~£230
Sigma 1.4 X EX DG APO Tele-Converter AF for Nikon AF Cameras ~£140
Sigma 1.4X EX Apo Tele Converter For Nikon ~£100
Sigma 2X EX DG APO Tele Converter AF for Nikon AF Cameras ~£150
Sigma EX Apo Tele Converter X2 , 2X for Nikon ~£140
Kenko PRO 300 AF 1.4x Teleconverter for Nikon AF-S ~£100
Kenko PRO 300 AF 3x Teleconverter for Nikon AF ~£120
Kenko Teleplus DG 1.5X MC Teleconverter For Nikon ~£85
Kenko Teleplus DG 2X MC4 Teleconverter for Nikon Mount ~£85
Kenko Teleplus DG Extension Tube Set 12+20+36 for Nikon AF ~£100
Am i right in believing out of all that lot, only the Nikon ones will support AF on the AF-S lenses? If so, how do people find using manual focus in macro photography? What difference does a teleconverter make to a plain extension tube?
Diopters.. are they any good? What makes should I be looking at? How well do they combine with teleconverters/extension tubes.
And fianally, what lenses should i be looking at to use in combination with/instead of all this lot? How well would be current stock 18mm-55mm stand up to doing macro work with attachments? Also, if people see no problem with manual focusing(I don't think I would), should I be looking at older manual focus lenses rather than AF-s ones?
