Nissan Juke - USB overrides Bluetooth: fix?
22 Jan 2014
Afternoon OcUK,
Currently in a Nissan Juke rental car, and the USB device connected overrides the Bluetooth device connected...so you have to listen to what's on the phone being charged rather than anything else!
Anyone know a fix for this?
Just want the Bluetooth to override/have music priority over the one connected by USB.
Cheers
Are you trying to stream music over Bluetooth, ie Spotify etc? If so just hit play, it's overridden the USB connection in the rental cars that I've had in the past.
iTunes, but pressing play just goes with the iTunes on the USB iPhone rather than Bluetooth. Pressing play on the Bluetooth iPhone just plays through the phone's speaker unfortunately.
Presumably it has a source button to change to a different input? Seems really bizarre if it wouldn't and such a flaw would have been overlooked to be honest.
It looks to think it's the same device connected by USB and Bluetooth, that's what's causing the problem...even though the USB iPhone has BT switched off. Most peculiar.
French radio it is :eek:
