No printer Courier recommendations
Caporegime
13 Jan 2010
Llaneirwg
Anecdotal evidence incoming
Need to send a monitor back and have no printer.
Anyone got any suggestions?
Looks like I'm fairly limited.
Was thinking of DX, parcelforce seems to be another option.
Yes our Co-Op has its own in store Hermes printer. Although I wouldnt trust Hermes with a monitor. Not many offer insurance for them either.
More serious answer:
I'm in the office today and will be going to the post office this afternoon, send me your label and I'll pop it in the post for you :)
Thanks for the kind offer,
What time would you be leaving? If there's time I'll get a dpd label.
Will only be going tomorrow now, just found out that this post office shuts at half 3 :confused:
Send me the label of you want, I'll post it to you first thing.
I used DX's 48 hour service recently for an RMA and they were spot on.
Collected from my home and they brought their own sticker/label.
Hermes I wouldn't trust with anything high value, although I've used them with cheaper/smaller parcels and some of their drop off points have a label printer.
https://www.parcel2go.com/ is a good resource for finding out which companies offer which services, including whether labels are provided etc.
R
Really appreciate this.
Means I can use dpd.
Ill get it measured up now.
I'm on dpd and soon as I type in 'monitor' it says prohibited.
Looks like it's going to be DX I guess.
Not insured for damage. But thy seems impossible to get
A little old but you could check if iPostParcels still cover monitors.
Ipostparcels cover monitors up to 40" I think? They're pretty good.
Looks like they're part of DHL so I've contacted them as there doesn't seem to be any mention of monitors being prohibited. Thanks.
EDIT: They've responded and have confirmed they allow monitors and will cover loss/damage.
Parcel2Go prohibit monitors across the board of their couriers.
Max size is not big enough (it's a long box) for ipost
Probably got no choice but parcelforce
Its not protected but at least it isn't prohibited
Did you not get my email? :confused:
I did, I sent you a reply. As its gonna have to be parcelforce I can just do it in the post office.
I've checked all the couriers and can't find one that will insure a monitor at all
Parcel2Go prohit them on all thier services
Dpd prohibit them
DX don't seem to have a portal for sending direct
Hermes don't even insure for loss
Only one I can find is parcelforce that will insure for loss
Dpd prohibit them
Missed your email somehow! Good luck, seems like sending a monitor is a bit of a PITA.
