Allo,
this is my first post in here as I only recently took up photography and recently graduated to a Canon EOS 350D.
What I basically do is go to gigs and take pictures on full manual without flash - or occasionally with the flash intensity dropped as low as possible and having it trigger on the 2nd curtain. However I don't like using flash at all and would generally avoid it.
The problem is with the 350D when I whack the ISO up the noise is awful, so my question is really pretty simple.
What camera next?
Literally the only thing I need is to have very low noise at higher ISO settings, ideally at 1600+ when used without flash. Hoever reviews aren't helping me massively with which to go for really as they don't always make it overly clear.
Can anyone help me out with some tips on what model I should be after? (I've got a bit of saving up to do, so that will give me time to badger OcUK staff to stock it
Thanks in advance
What camera next?
).Thanks in advance
