- 19 Jun 2003
- West Yorks, UK
Hi all,
So I bought a Nokia N73 from the auction site, and it worked fine for a couple of hours. I ran the Nokia Software Updater on it, which seemed to encounter some problems as it asked me to remove the battery, re-insert it and try again.
However, the update said it completed sucessfully in the end. Now though, the phone won't boot - it just ends up on a screen saying "Phone start-up failed. Contact the retailer". I've had a Google, and it looks like to hard reset, you can hold CALL + 3 + * whilst you power it on. This doesn't appear to do anything for me, as the phone still comes up with that message.
Is there a more failsafe way to reset the thing?
Matt
Matt
