this will destroy the 2nd market and I like it![]()
Just what I was thinking
Have these dropped again ?
Gibbo always find the shortest way to new price actions. I am not worried about that. He's a great guy with the right job.
Isn't the 1070 faster and cheaper than the 980ti?
I've not played with a 1070 yet but from talking with board partners they say this:
Stock 980Ti vs Stock 1070, the 1070 pretty much wins all the time.
But the 1070 does not overclock anywhere near as well as 980Ti, so say a 980Ti such as EVGA SC/FTW or Zotac AMP actually rivals 1070 and can beat it.
When both cards are OC to maxed, the 980Ti tends to win as 980Ti is simply a far better overclocking GPU.![]()
Yeah that pretty much sums it up. If you're going to plug and play then go for a 1070 but if you're overclocking go for the 980Ti. That said, it could change if driver improvements occur which could push the 1070 higher OC vs OC but here and now the 980Ti is faster when comparing overclocked results.
Drivers from experience do not help much with OC ability, they can just unleash additional performance.
Yeah that pretty much sums it up. If you're going to plug and play then go for a 1070 but if you're overclocking go for the 980Ti (second hand probably best). That said, it could change if driver improvements occur which could push the 1070 higher OC vs OC but here and now the 980Ti is faster when comparing overclocked results.
Indeed. The 1000 series is showing improvements in DX12 aswell, and as you say with driver improvements the gap is only going to widen. Going forward, i wouldn't even consider a 980Ti at this point, unless it was cheaper. The 980Ti is only going to be slightly faster if you get one that can consistently hold 1450mhz+ stable.
People are upgrading from 980ti's to 1070's?? Why on earth would you bother? Surely the performance is so close as to make no difference?
