nyone else having problems connecting a k800 to windows 2000?
18 Oct 2002
I'm having real difficulties attaching my k800 to my windows 2000 box at work.
I've downloaded the latest drivers from SE and installed them without any issue. However, when i attach the phone it picks up the modem feature straight away, then, when i switch to file transfer mode, it tells me that i have disconnected the modem without safely unplugging it. After which the drive letters for the phone and m2 card appear in my computer, but they are not accessible and if you try to access them it tells you that no disk is inserted. Also, you cannot safely unplug the phone as there is nothing to select in the safely remove hardware icon and therefore you have to power down the machine to remove it safely.
I've tried re-installing the drivers a couple of times, but had no luck at all.
Does anyone have any suggestions
Many thanks
Spud
PS couple of extra points of info - i have an administrator account on the windows 2000 box, i've not installed the pc suite as i don't want it clogging the machine up, the phone works fine on my windows xp box at home
