SPECS
. 5 fan capability (side 120mm LED and rear 120mm exhaust included)
. Included 9-fin rifle bearing NZXT fans rated at 42CFM and 23db
. An ambient light sits over the 5.25″ drives to give visibility in dark rooms or at LAN parties
. Smoked clear window and a black interior gives the best combination of black on black
. Meshed front panel allows for more airflow
. 5.25″ stealth bay to keep a clean look
. NZXT solid state bracket allows for two SSD drives to be installed
. Motherboard punched holes allows for quick CPU bracket removable and optimal wire routing, turned HDD also helps with managing cables
. Pre-drilled water cooling holes on the back plate
. Front mounted USB, audio, and eSATA ports
. Support for external dual radiator at the top of the chassis
. High end graphics card support, the M59 features space that is especially designed to fit longer 10″ card.s
Reviews
http://icrontic.com/articles/the-nzxt-m59-case-reviewed
http://www.pcgameshardware.com/aid,689137/NZXT-M59-New-case-introduced/News/
