NZXT Phantom Enthusiast Cases in both black and white. IN STOCK N0W!
not to keen on this case as i dont think it will be very good at air cooling as in its standard form it will be extracting more air then letting in, also its got a very nice layout internally but what good is that with out a window to see it ?
Just finished putting everything in. It is absolutely silent, fantastic to build in and is without doubt the best made case I have had the pleasure of using.
Even with all the fans turned to minimum, my Fenrir at 50% and my GFX card fan at 30% the temps are fantastic.
Thank you OCUK for this fantastic bit of kit, and also to NZXT for making it.
Good to see you are a happy bunny :)
Just been fiddling around with overclocking, amateur stuff really.
Went straight for 3.8 ghz with a 181 Bclck and 21x multiplier, 1.272V :O LLC and SMT on, with ram at 1448mhz.
With fans and fenrir at 100% (stock fan configuration) am well under 70 degrees, core 2 hitting 63 under prime :O. And fully Stable :)
This, frankly, is amazing considering even at max speeds it's a hell of a lot quieter than my Antec 900.
Cannot reccomend this case highly enough :)
Rather large, but yes, cooling ability is amazing, room inside is, well, roomy :D and it is silent. So if that's your idea of practicality then definitely get one! :)
well I got a HAF atm its just a little big and........errr ugly but it has lovely features, and the cooling O_O
I m consdering re doing my system thats all.
Which HAF? If you have the 932 or X no point really, if you have the 922 then definitely.
Although, according to Bit-Tech the Phantom has similar cooling capabilities even with the stock fan setup set to minimum.
And it looks a hell of a lot nicer :)
932, before that I had a tt armour....huge inprovment, i m consdering building a new build I dunno to upgrade over time or to sell this holding back the GPU, and get this or the HAF X. Coolermaster seem to be on the ball atm with cases
