Nzxt x62 mobo connection?
29 Aug 2009
I've got a nzxt x62 liquid cooler and i need help with where to connect the fans and pump to the mobo. The mobo is a asrock x370 gaming k4 and the case is a nzxt s340 elite with 2 case fans.
On the mobo there is :
- 1 x CPU Fan Connector (4-pin)**
- 1 x CPU Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)***
- 2 x Chassis Fan Connectors (4-pin) (Smart Fan Speed Control)****
- 1 x Chassis Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)****
At the moment the case fans are just connected with a molex cable and the nzxt x62 fans are connected to the splitter cable coming from the nzxt pump, there is 1 4 pin connector and 3 3 pin connectors. So whats the best way for me to do it ? Thanks
30 Jun 2006
Cardiff
Hi. You connect the 4 pin to the 4pin cpu header on your motherboard. Leave the fans connected to the leads coming off the pump and just alter the rpms in bios and set a fan curve. You will also need to install the cam software.
