OC AND HAZRO MONITOR MADNESS
Can i ask what graphics card you are using to power the Hazro?
Also, did you use a dual link DVI cable or a single link DVI cable?
The reason I ask what graphics card is because I am sure there were certain cards that just would not work with the hazros. Also, some AMD graphics cards have 2 DVI connections but only one of these connections are DL-DVI and the other is a SL-DVI which won't work on a high res monitor. It just seams strange that overclockers tested it and it worked.
