** OcUK HAS THE LARGEST RANGE OF NVIDIA 9xx SERIES REFERENCE CARDS IN STOCK!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
As I warned every one at the launch of GTX 980 that reference design cards were pretty much end of life the moment they were released and that board partners would move focus onto their own designs only. You will find now if you look around the UK the only 980 reference card typically in stock is the Palit 980 and in very small numbers, for example both our two largest competitors have less than ten units in stock each and Palit are making no more.
I warned this was the case and at the time went buying all the 980 reference cards I could find in the UK, Europe and Far East.
As such I now present you the largest in stock range of 980 reference cards including a 970 as well:
Asus GeForce GTX 980 "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card @ £499.99 inc VAT
The new NVIDIA GeForce GTX 980/970 is powered by the next generation NVIDIA Maxwell Architecture, giving you incredible performance, unmatched power efficiency, and cutting-edge features.
Maxwell is the most advanced GPU architecture ever made, designed to be the engine of next generation gaming. Inspired by light, it was designed to solve some of the most complex lighting and graphics challenges in visual computing. For the first time, gaming GPU's can dynamically render indirect light using the new VXGI (Voxel Global Illumination technology). Scenes are significantly more lifelike as light interacts more realistically in the game environment.
The GTX 980 is the worlds fastest GPU and the GTX 970 offers the most advanced performance in its class. Each delivers 2x the performance of previous-generation card, bringing new gaming experiences to virtual reality, and ultra resolution 4k displays.
Enable the detail of 4k monitors, on a 1080P display. DSR produces smoother images by rendering a game at a high resolution, then downscaling it to the native resolution of the display using advanced filtering.
GeForce GTX 980 and 970 cards support tear-free, super-fast NVIDIA G-Sync monitor display technology including 4k. Together, these technologies provide the most immersive and competitive gaming experiences possible.
Features:-
- Voxel Global Illumination Technology (VXGI)
- NVIDIA® Super Resolution technology
- NVIDIA® GameWorks technology
- NVIDIA® GameStream technology
- NVIDIA® TXAA Technology
- NVIDIA GPU Boost 2.0
- NVIDIA PhysX® Technology
- NVIDIA FXAA Technology
- NVIDIA Adaptive Vertical Sync
- NVIDIA Surround
- Support for four concurrent displays including: Two dual-link DVI, HDMI and DisplayPort 1.2
- Microsoft DirectX 12
- NVIDIA® 3D Vision® Ready
- NVIDIA SLI® Ready Technology
- NVIDIA CUDA® technology
- PCI Express 3.0 support
- OpenGL 4.4 support
- OpenCL support
- NVIDIA SHIELD Ready
- NVIDIA G-Sync Ready
Specification:-
- GeForce GTX 980
- GPU: GeForce GTX 980 (GM204)
- Core Base Clock: 1127MHz
- Core Boost Clock: 1216MHz
- Memory Clock: 7010MHz
- Memory Size: 4096MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 256-bit
- CUDA Cores: 2048
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Dimensions: 268.6 x 98.4 x 40 mm
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
Only £499.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 980 SC "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card (04G-P4-2982-KR) @ £529.99 inc VAT
The new EVGA GeForce GTX 980 is powered by the next generation NVIDIA Maxwell Architecture, giving you incredible performance, unmatched power efficiency, and cutting-edge features.
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- Core Base Clock: 1241MHz
- Core Boost Clock: 1342MHz
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
Only £529.99 inc VAT - More stock due next week!
ORDER NOW
GALAX GeForce GTX 980 "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card (98NQH6DHXXXX) @ £479.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 2yr
Only £479.99 inc VAT.
ORDER NOW
Inno3D GeForce GTX 980 "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card (N980-1DDN-M5DN) @ £449.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 2yr
Only £449.99 inc VAT.
ORDER NOW
MSI GeForce GTX 980 "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card @ £469.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
Only £469.99 inc VAT.
ORDER NOW
OcUK GeForce GTX 980 "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card @ £439.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
Only £439.99 inc VAT.
ORDER NOW
Palit GeForce GTX 980 "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card (NE5X980015G2-PG401F) @ £439.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 178W TDP
- Warranty: 3yr
ORDER NOW
Zotac GeForce GTX 980 "Reference Design" 4096MB GDDR5 PCI-Express Graphics Card (ZT-90201-10P) @ £449.99 inc VAT
Features:-
- NVIDIA Surround
- OpenCL support
Specification:-
- GeForce GTX 980
- CUDA Cores: 2048
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 6-Pin
- 500W PSU Required
- 165W TDP
- Warranty: 5yr (2yr +3yr FREE when you register the product with Zotac within 28 days of purchase)
ORDER NOW
OcUK GeForce GTX 970 "NVIDIA 970 Cooler Edition" 4096MB GDDR5 PCI-Express Graphics Card **WorldWide Exclusive** @ £319.99 inc VAT
nonl2br
This very special NVIDIA GeForce GTX 970 is the only one of its kind designed by our in-house VGA Guru Gibbo making this the worlds ONLY genuine reference 970 available in the world. Gibbo's design request were very specific, genuine NVIDIA 970 cooler, yes the crazy expensive one just like the 980 cooler and a NVIDIA BGA Board using all original NVIDIA components with absolute zero cost down in the design.
<br>
<br>
Infact Gibbo improved the design by changing the containers in which the inductors are located for better quality items to help reduce and eliminate any possibility of coil whine. We also instruct our factory to only build these cards with Samsung memory. So why buy this over any other 970, well it is most likely the quietest whilst under load (gaming) due to having the NVIDIA cooler and any chances of coil whine have being pretty much eliminated with the design changes Gibbo has had implemented.
<br>
<br>
So this card is ideal for those seeking as little noise as possible and the other major advantage is the NVIDIA cooler which offers much better cooling performance in smaller enclosures or when running in 2-way or 3-way SLI.
<br>
<br>
Finally of course this card is perfect for when Half Life 3 is finally released at some point in the future and of course the latest GTA V game which is now confirmed!
<br>
<br>
The GTX 980 is the worlds fastest GPU and the GTX 970 offers the most advanced performance in its class. Each delivers 2x the performance of previous-generation card, bringing new gaming experiences to virtual reality, and ultra resolution 4k displays.<br /><br />
Enable the detail of 4k monitors, on a 1080P display. DSR produces smoother images by rendering a game at a high resolution, then downscaling it to the native resolution of the display using advanced filtering.<br /><br />
GeForce GTX 980 and 970 cards support tear-free, super-fast NVIDIA G-Sync monitor display technology including 4k. Together, these technologies provide the most immersive and competitive gaming experiences possible.<br /><br />
Features:-<br />
- Voxel Global Illumination Technology (VXGI)<br />
- NVIDIA® Super Resolution technology<br />
- NVIDIA® GameWorks technology<br />
- NVIDIA® GameStream technology<br />
- NVIDIA® TXAA Technology<br />
- NVIDIA GPU Boost 2.0<br />
- NVIDIA PhysX® Technology<br />
- NVIDIA FXAA Technology<br />
- NVIDIA Adaptive Vertical Sync<br />
- NVIDIA Surround<br />
- Support for four concurrent displays including: Two dual-link DVI, HDMI and DisplayPort 1.2<br />
- Microsoft DirectX 12<br />
- NVIDIA® 3D Vision® Ready<br />
- NVIDIA SLI® Ready Technology<br />
- NVIDIA CUDA® technology<br />
- PCI Express 3.0 support<br />
- OpenGL 4.4 support<br />
- OpenCL support<br />
- NVIDIA SHIELD Ready<br />
- NVIDIA G-Sync Ready<br />
<br /><br />
Specification:-<br />
- Genuine NVIDIA 970 Cooler with Visualizer<br />
- Genuine NVIDIA 980 PCB<br />
- Samsung memory guaranteed<br />
- Coil Whine reduction technology: We specify the capacitors/inductors to be enclosed in plastic containers as it helps reduce/eliminate coil whine<br />
- GeForce GTX 970<br />
- GPU: GeForce GTX 970 (GM204)<br />
- Core Base Clock: 1050MHz<br />
- Core Boost Clock: 1178MHz (Upto 1268MHz Boost)<br />
- Memory Clock: 7010MHz <br />
- Memory Size: 4096MB Samsung GDDR5<br />
- Bus Type: PCI Express 3.0<br />
- Memory Bus: 256-bit<br />
- CUDA Cores: 1664<br />
- DirectX 12: Yes<br />
- DVI Port: 1x Dual-Link DVI, 3x DisplayPort & 1x HDMI<br />
- DisplayPort: Yes <br />
- HDCP: Yes<br />
- HDMI: Yes<br />
- Power: 2x 6-Pin<br />
- 450W PSU Required<br />
- 145W TDP<br />
- Dimensions: 268.6 x 98.4 x 40 mm<br />
- Warranty: 3yr<br />
Only £319.99 inc VAT.
ORDER NOW
Going forward we will soon run out and never see again the Asus, Galax, Inno3D, MSI, Palit and Zotac 980 reference cards.
We can still get the EVGA 980 reference Superclock but the cost to us dramatically increased as is reflected in our sell price.
Our own OcUK reference 980 right now has an uncertain future, so we cannot guarantee sourcing more stock. :(
So yes the prices have gone up and yes the product is very short and I predict by end of January next year there shall be no reference 980 available except for maybe the EVGA card at its crazy high price.
The limited availability won't apply to the 970 reference will it? I have one already, looking to perhaps get another early next year.
The price on that won't move up much if at all, we're looking to schedule our next batch for delivery end of January.
£320 for 970? I doubt the cooler is £60-70 better.
Depends in what circumstances and to who ... Standard users with single cards , unlikely ... Power users or enthusiasts with micro ATX builds or multiple card configs , certainly
