** OcUK Tech Labs: Extreme CPU Liquid Cooling Upgrade Bundles **
rjk
rjk
Caporegime
8 Aug 2007
As Promised yesterday, we have a range of upgrade bundles available which are designed to allow you to upgrade your OcUK system to an all in one liquid cooling solution.
These bundles offer great price and performance as well as an attractive stealth look.
We use these coolers as an upgrade option in some of our system builds and they are absolutely stunning.
The cooler in this upgrade bundle comes from Asetek, market leaders in data centre liquid cooling solutions and the OEM manufacturer for many premium component brands AIO solutions. Asetek back their AIO solution with a 2 Year warranty which is handled in house here at OcUK for a rapid turnaround should the worst happen.
Paired with the award winning OcUK FQ121WC Watercooling fan and a host of socket and fan controller options, there is something for every user.
Every cooler comes with a 2.7g tube of Arctic Silver Céramique 2 Thermal Paste. This is enough for multiple applications but will ensure that your cooler is performing at its absolute best.
Check out these pictures of the coolers in systems.
OcUK Tech Labs 120mm Extreme CPU Liquid Cooling Upgrade Bundle @ £69.95 inc VAT
Tame your CPU with the OcUK Tech Labs Extreme All In One CPU Liquid Cooling bundle
The entry level 120mm cooler is ideal for small space constraints or low heat output processors. The 240mm+ coolers are designed for more extreme applications and are ideal for cooling and overclocking high performance processors.
Paired with OcUK designed, watercooling radiator optimised fans, the Tech Labs All In One CPU Liquid Coolers provide superb value for money as well as incredible performance.
The AIO Liquid coolers in these system integration solutions are manufactured by industry leader; Asetek.
We ship every bundle with a tube of high performance Arctic Silver Céramique 2 Thermal Paste (2.7g). This is the ideal thermal paste for ultimate performance with your upgrade.
Every Bundle has an option to include an OcUK Tech Labs recommended Fan Control unit that will ensure that you get the very best out of your Cooling Upgrade Bundle
Each CPU cooler is unbranded with a smart, stealth appearance. No flashing LEDs, no corporate logos or garish branding.
Installation is easy and all mounting hardware and instructions are included. Please ensure that your chassis is capable of accommodating the size of radiator you choose.
Cooler Features:
- Heat Exchanger Size: 120x120x49 mm
- Gen 4 Integrated Pump and Copper Cold Plate
- Double Thick 120mm Aluminum Heat Exchanger
- Designed for Single Fan Operation
- Factory Filled and Sealed, No Relling Needed
- High Flexibility, Low Permeability Tubing
- 2 Year Warranty
Included in this bundle:
- Premium CPU Mounting Hardware
- Arctic Silver Céramique 2 Thermal Paste (2.7g)
- Asetek 120mm 570LC High Performance Compact AIO Liquid Cooling Solution
- OcUK FQ121WC Watercooling Radiator Fan
Only £69.95 inc VAT.
ORDER NOW
OcUK Tech Labs 240mm Extreme CPU Liquid Cooling Upgrade Bundle @ £74.99 inc VAT
Cooler Features:
- Heat Exchanger Size: 120x120x30 mm
- 2400mm Aluminum Heat Exchanger
- Designed for Dual Fan Operation
- Requires 2 adjacent 120mm fan ports
- 2 Year Warranty
- Asetek 240mm 570LXL High Performance Compact AIO Liquid Cooling Solution
- 2X OcUK FQ121WC Watercooling Radiator Fan
Only £74.99 inc VAT.
ORDER NOW
OcUK Tech Labs 240mm+ Extreme CPU Liquid Cooling Upgrade Bundle @ £79.94 inc VAT
Cooler Features:
- Heat Exchanger Size: 240x120x38 mm
- Double Long, Extra Thick 120mm Aluminum Radiator
- 2 Year Warranty
- Asetek 240mm 570LX High Performance Compact AIO Liquid Cooling Solution
Only £79.94 inc VAT.
ORDER NOW
OcUK Tech Labs 360mm Extreme CPU Liquid Cooling Upgrade Bundle @ £109.94 inc VAT
Cooler Features:
- Heat Exchanger Size: 360x120x30 mm
- Thick 360mm Aluminum Heat Exchanger
- Designed for Triple Fan Operation
- 2 Year Warranty
- Asetek 360mm 591LX High Performance Extreme AIO Liquid Cooling Solution
- 3X OcUK FQ121WC Watercooling Radiator Fan
Only £109.94 inc VAT.
ORDER NOW
