Hi all,
Well I installed my 120GB Vertex 2E and went about installing Windows 7 64bit.
Once installed, I disabled indexing, superfetch, defrag etc, updated motherboard drivers and so on. I ran CrystalDiskMark and only saw around 180MB/s for sequential read and writes even though I've seen people benching with 240 ish.
I then tried to install the intel rapid storage driver which failed basically saying something like no supported hardware. (I don't remember the exact message)
I found my bios was set to IDE on the sata interface and read that it should be set to AHCI for speed and also was the likely cause of the intel driver install failing. Is this correct?
Once changed over to AHCI windows begins to load but then BSOD's and restarts. Is this because I need to re-install windows with the ahci enabled now for it to work? WinXP on my old boot drive also failed with a BSOD whilst in AHCI mode.
Hope someone can shed some light
I'm probably doing it all wrong and not sure whether I should be installing the intel driver through device manager or something? Also would there be any issues with running my samsung spinpoints on ACHI for storage.
thanks
Spencer
thanks
Spencer
