http://www.overclock.net/t/1398725/u...tx460-with-llc Rbby258 ABvoltmob
The postman arrived
The postman arrived
Got two of these bad boys arriving tomorrow!
So excited.
Can you guys help me get e'm to 1.3ghz core and 7ghz V-ram
Jerry is that using AB?
I'm not use to these gpus, u think you raise core and the card still boosts above that?
What do I set power limit to?
Well mine will only go 23mhz above stock it seems
mem is ok at 7GHZ
I'll try again and see what the message is.
Oh and is LN2 BIOS with switch to the right?
Because Gpu-z is showing the exact same Bios in either switch position?
Ok my bad I wasn't installing vers 14 of the 3.0 beta like you said I tried another version which didn't work, this one does now
