Hi all,
I turned my main PC on yesterday, or I tried to. Its an older home build PC circa 2013 with a 3570k Intel CPU, Gigabytee Z77-D3H mobo, 8gb patriot ram and a Pallet 970 GPU, running windows 10. The only reason it has not been upgraded has been adding 500gb Samsung pro SSD and it still felt fairly nippy.
Anyway, on turning it on last night I kick-started a sequence of events which I have not been able to sort out yet. Initially the PC was on but nothing was on screen. After a few restarts and a delve into the bios I realised I could connect the HDMI cable to the main PC output and get the image back, so GPU then? I then made a mistake and disabled the mobo screen output in the bios and tried the GPU again. I could not get the GPU to work and couldn't get back into the bios. Mistake 2, to fix the first I pulled the cmos battery, which meant I could get back into the bios and fix mistake 1. However ever since then I cannot find a set of stable settings to run the PC, and I cannot find a way to put the bios back to default. No matter whether I try last know good configuration, a close approximation of the default settings or me playing around under the hood, the same thing happens. The PC will boot, post but crashes on the windows start screen. I am now wondering whether the Corsair PSU or mobo are at fault. It just turns off very abrubtly as windows starts to load. I can however boot into safe mode. Could this be a software issue, or is it likely hardware?
Anyway, I had hoped to last until the summer before buying again, does anyone have any thoughts or tips to try?
Luckily I think all my stuff is backed up on Onedrive and my NAS, although recreating the regime on any new PC is already making me nervous! lol.
Cheers
Cheers
