Omega Drivers - No AA + HDR For Oblivion?
3 Dec 2004
Hello,
Im using the latest Omega drivers (as i cant get the CC to work with the official ones),how do I get AA And HDR to work. I thought I needed to turn AA on in the conrtol settings and HDR on the menu - im having no luck.
Regards
I'm sure you need the ati driver and the "chuck patch" to get aa + hdr to work in Oblivion. I'm sure someone on here will tell you if the chuck patch works with the omega drivers or not.
Yeah you can only get AA+HDR with the chuck patch, i cant see why it wont work with the Omegas, as you just install the chuck patch over the top of either (Cat's/Omegas), then you just enable AA in the drivers, and the HDR in game. :)
