Ordered a bunch of stuff, forgot to check if compatible.
17 Aug 2012
England
I was in a bit of a rush this morning and ordered components for my computer. However, I after looking at my order list I am now unsure if some things will fit.
The ones I am unsure about are whether my Sapphire Radeon R9 Nitro 390 will fit my case, a Cooler Master Silencio 550 Silent Tower Case.
The other thing I was unsure on was whether the SuperFlower Leadex GOLD 550W Fully Modular '80 Plus Gold' Power Supply is good enough to properly power the 390 and an i5 4690k
Thanks
Asus Z97-K Intel Z97 is the motherboard and Kingston HyperX Savage Red 8GB for the RAM
The GPU will fit, providing you remove the central HDD cage
The Superflower is an excellent unit and will easily power your components.
