You need a graphics card as well, something 2d and cheap I imagine, probably passive. SB gpu doesn't work on the P67 chipset
Doubt you need the Maximus IV level, thats overkill really, you could get away with the MSI P67A-GD55/65, Asus P67A-Pro something uncomplicated and mid-range. The less "features" the better really.
Memory wise similar. You can't really overclock the FSB on the SB chipsets, its all down to the multi on the cpu. So you can go top dog on the memory, but research cool running at 16000 low voltage as long as it does C1 with low latency you should be rocking
Unless your application is bandwidth starved, but it doesn't sound like it if its not multi-threaded. Obviously its your budget but the money you save per unit could easily pay for more units
