Caporegime
IPC is inter process communication - something that is completely irrelevant to us as we're running a single threaded app. Also, the 12MB of cache is of interest, but only in instances where we're utilising more than one core for each instance of our application - i.e. 4 cores - 3 x our application, 1 dedicated core for OS.
As for stability, I'm running Intel Burn Test/Linpack for at least 8 hours.
The Core i7 processors I mentioned are dual cores running at 4.66GHZ with more L3 cache per core than a normal Core i7 quad or six core processors. Of course Turbo is probably active too meaning it is most likely that the actual clockspeed is slightly higher too.
BTW,8 hours testing ONLY??
I test my overclocks for 24 hours at least. You do realise that even then all the stability testing is telling you is that the overclock is stable for the tested time period under load.
Do you intend to repeat the stability testing at 1 month,2 month,3 month,6 month and 12 month time points to ensure the CPUs are entirely stable still??
