** Overclockers UK & SilverStone - 120mm FQ121WC Watercooling Radiator Fan **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
At long last, I am delighted to announce immediate availability of the fan that I have been working on with Silvetstone.
This fan is not designed to be the 'ultimate performance' solution for watercooling. We are placing this product as an affordable option that provides close to Gentle Typhoon performance and provides exceptional bang for buck.
When building a liquid cooling system, you may be fitting multiple fans to your radiators. This starts getting very expensive when you have a pair of 480 radiators or more.
I designed this fan to run from a fan controller as watercooling should be manually controlled using either analogue fan control units or Smart controllers.
There are a load of little design features I asked for as well to complete the package, flat cables, black connectors, removal of stickers from the front of the fan etc.
I am arranging the fan to be tested alongside other watercooling fans so you can get a proper sense of what it is capable of.
Given the price and original target I set out to achieve, I firmly believe this is the best budget fan for watercooling enthusiasts right now.
I even did a triple pack so you can save money when buying in bulk!
Overclockers UK & SilverStone - 120mm FQ121WC Watercooling Radiator Fan @ £9.95 inc VAT
Watercooling enthusiasts have typically been left with slim choices when picking a suitable fan for their projects. Specialist cooling fans developed for Liquid Cooling tend to have a significant price tag associated with them and make adding multiple fans to large projects being
The FQ121WC fan from SilverStone sets a brilliant baseline for Liquid Cooling performance featuring high quality components and impressive specifications at a great price point. We have worked with Silverstone to produce a more focussed product that is entirely aimed at Watercooling, Performance and Hardware Enthusiasts that doesn't break the bank.
Not only is the FQ121WC perfect for bespoke liquid cooled system projects, but it makes a worthy upgrade for AIO Liquid Cooler users.
A number of small but significant changes were made to the product to refine it and make it a real prospect for people looking for exceptional performance at a wallet friendly price.
The FQ121WC is completely black with minimal stickers and branding to ensure that hardware modders have a great base for painting and customisation. The fan blades can be easily removed from the fan motor and the blades are made from the same high quality PBT plastic that the FQ121 fan it derives from. This ensures a solid and premium product feel as well as being hardwearing and durable.
The PWM feature from the original fan has been removed in favour of a 3 pin connector. This change was made to be compatible with fan control units and smart controllers such as the Aqua Computer Aquaero. This fan is designed to be used with fan controllers to give you the best performance and speed/noise output.
The Cable of the FQ121WC is flat to ensure that cable management is easy and that cables can be layered on top of each other in tight spaces when the fans are placed next to eachother on watercooling radiators.
The cable and connector are both black to ensure a stealth and uniform appearance.
Features:
- Custom design meeting the needs of Hardware and Liquid Cooling enthusiasts
- Optimum airflow, pressure and extremely silent performance
- Specified for Watercooling application
- Innovative blade design focuses airflow with maximum efficiency
- Air-inlet with optimized aerodynamic design reduces noisy air turbulence
Specifications:-
- Model No. FQ121WC
- Material P.B.T.
- Color Black blade/black frame
- Bearing P.C.F. bearing (Powder Copper Fluid Bearing)
- Rated Voltage 12V
- Start Voltage =7V
- Speed: up to 1,800rpm
- Airflow 67.5CFM (at maximum speed)
- Static Pressure 0.54 – 1.82mmH2O
- Noise Level 16.4 – 24 dBA
- Life Time 150,000 hours
- Weight 143±5g
- Dimension 120mm (L) x 120mm (W) x 25mm (D)
Please note - This Fan is shipped without a box in OEM format to reduce packaging weight, shipping costs and impact to the environment.
Only £9.95 inc VAT.
ORDER NOW
Three Fan Bundle - Overclockers UK & SilverStone - 120mm FQ121WC Watercooling Radiator Fan @ £20.99 inc VAT
Was £29.84 Inc. VAT
Only £20.99 inc VAT.
ORDER NOW
Hooray - they are here, but which is better the new EK fans or these in terms of performance/noise etc. I will be using a controller anyway. So which should I go for? :)
Mark
the EK will probably be a bit better as they have been developed exclusively for WC use rather than being modified for WC use
the EK fan is more expensive though so it depends what you want
Many thanks Richard - shall try the ek fans then - any chance of a 4 pack special? Go on you know you want to really:D
Mark
maybe
thing is that we have loads of stock of the OcUK fan and limited stock of the EK as they are brand new.
if you like.
I could do with a cash injection into the 'rjkoneill outrageously expensive car parts fund'
Could you do a dual pack mate? As it stands I would be just as well buying 3 for a push pull single rad...
Out of interest, think corsair H60 type block, would a pair of these in push and pull be a good combo - ie for an AIO double depth rad?
Probably the EK, but waiting for results on that.
the EK are more money than these though.
they were never designed to compete, they just offer neat GT performance for not much cash
Marketing are doing the pics for me. They are slammed sorting 8pack stuff at the moment so I was lucky to get the default pic
Should hopefully have the rest tomorrow and will update the thread.
