** Overclockers UK & SilverStone - 120mm FQ121WC Watercooling Radiator Fan **
You really shouldn't dismantle the GTs, the bearing is set carefully on a balance so odds are likely you will upset it. It may have an effect on performance and longevity.
I disassembled to use a die on the blades and they ran just as silent for over a year, then i switched rigs so i don't know about further longevity.
