try ram at 3,3,3,8, fsb at 250, ht at 4x and multiplier at 10.5 with the 9.9%. then if that is ok for a prime run of a few hours up the multi to 11, i don't think your going to get it any higher than 2750 at best with the voltage options on your board, so that would be the best settings for you if they work i think.
if you manage to get the 2625 running fine with the 10.5 multi and not 2750 with the 11 multi then it will be your cpu voltage that is limiting you
i dont use msn or have anything else we could talk on i'm afraid.
there is no need to set the ht to 3x as i have never used a 939 board that can't handle a 1040 ht link, its only when you go above 1100 that you need to start lowering it on some boards.
