1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Part 2 - Kitchen (DIY-KITCHENS) refurb and load bearing wall removal
Discussion in 'Home and Garden' started by PaDE, Apr 27, 2019.
  1. PaDE
    Gangster
    They are 'Sequoia light oak beige' porcelain wood effect tiles with textured wood grain effect. Look convincingly real.
  2. 1mm3
    Hitman
    Is the floor and room not cold without having underfloor heating?
    Really like the look of polished porcelain for an open plan kitchen dining room. Already has concrete floor and retrofitting looks too expensive.
  3. PaDE
    Gangster
    Not really noticed it being cold
  4. Mark M
    Mobster
    Spoke to the plumber that I use who is a right laugh and asked him the same sort of question about underfloor heating for a massive kitchen/diner and hallway. He sucked his teeth for a bit and said I rekon it will be about £6k fitted or I can save us both the bother and I'll buy you a pair of slippers :D
  5. SimonR
    Hitman
    That was similar to the quote my builder gave me for my extension 34m2. Honestly, with decent insulation under the floor I dont notice the floor being cold and I walk around bare foot.
  6. spluff
    Wise Guy
    Just wondering how big is your island what space is around each of the edges and is it comfortable for your space..... thanks
  7. PaDE
    Gangster
    The island is basically 2 x 600mm Pan draws with a 250mm overhang with the worktop.
    There's around 3ft distance on 3 sides and 3.5ft on the Fridge freezer side. More than enough space to be honest.
  8. spluff
    Wise Guy
    Thanks Pade...
    We looking at getting island 1785 x 900
    With space around
    905 sink area
    1095 door
    970 wall but will be stools
    1150 cooker will be a stool
    Hopefully will be fine
  9. PaDE
    Gangster
    You'll be fine with that.
    When designing, most places say 1000mm with the caveat that 900mm is no issue anyhow.
    Good luck!
  10. spluff
    Wise Guy
    cheers will maybe create a new thread for inspiration and ideas too - its so hard to work out what I want...…..
  11. TripleT
    Sgarrista
    Looks stunning congrats.
    Where did you get the radiators from out of interest? (I sell them so curious that's all :p)
  12. PaDE
    Gangster
    Thanks TripleT
    We used BestHeating.com for all our rads
  13. TripleT
    Sgarrista
    Boo :p
