- 1 Dec 2015
FWIW i think the 'wrong' side panel looks better than full clear
Parvum making a full clear so will see which one looks best. will admit when you walk around it and see the seemless edge between the clear side panel and the front it looks finished but carrying around the the framed panel doesn't. Guess it has to be one or the other and not mixed.
Might take a photo with the PSU panel swapped with the framed panel as a reference
Guessing if the Framed panel was a thin bezel it could look good but default one is far to bulky for this design in my view
Ah, gotcha!
Well, it would seem the screen inclusion would have more benefits than just the aesthetics - plus others will prefer it too - it's still in keeping with the modern/sleek look
Look forward to seeing that - your design should lend itself really well to that type of case.
Kudos - really - looks great.
seems the frosted midwall is about 6" which is 50mm to short i think for 7" screen- may have to mount it vertical. If so a 10.1" screen could also work being mounted vertical but not sure if it can run off USB power alone
HAHAHA - just got a message saying the case looks like the Castle from Frozen
