Hi forum,
first post, first oc. been reading here plenty so thanks for all the advice!...will post my efforts in greater depth in another thread if I can get past this prob.
Have hit 3.2GHz on my dual core E4600 with a fair bit of pushing. I've hit 22 hours on orthos small fft and blend for 12 hours stopping both manually. Max core temps are creeping over 60 during small fft, rest is further below.
After a successful boot and test, I reboot and system fails at POST. I can drop Nb voltage down by 0.02 and 2nd boot works but will fail blend after 6 hours.
I'll fiddle some more or try at 355x9 to see if I can get better results. In the meantime, any help/advice is appreciated...
cheers all
Asus P5Q-Pro with Ket's 1406 bios mod
E4600
OCZ Platinum Rev2 2x1GB 800MHz DDR2 4-4-4-15
Scythe Ninja 2
Antec P182
Gainward HD3850 512MB DDR3
eXtreme Power Plus 460W PSU
Boot HDD: WD 40GB IDE
2nd HDD: Seagate Barracuda 150GB IDE
3rd HDD: Seagate ST3500320AS 500GB SATA2
Multi: 10x
Fsb: 320MHz
pcie: 100MHz
fsb strap nb: Auto (5-5-5-13)
dram freq: 802MHz
dram timing: Auto
dram static: disabled
dram read: disabled
mem oc: enabled
ai twister: light
ai transac: man
Common performance level: 11
all pull-ins: auto
Core: 1.43125v
cpu gtl: 63x
cpu pll: 1.5v
fsb term: 1.22v
dram: 2.0v
NB: 1.42v
Sb: Auto
pcie sata: auto
Load Line Calibration: enabled
CPU Spread Spectrum: disabled
PCIE Spread Spectrum: disabled
CPU Clock Skew: Auto
NB Clock Skew: Auto
CPU Margin Enhancement: Optimized
cheers all
E4600
Scythe Ninja 2
Antec P182
Multi: 10x
Fsb: 320MHz
pcie: 100MHz
dram freq: 802MHz
dram timing: Auto
dram read: disabled
mem oc: enabled
ai twister: light
ai transac: man
all pull-ins: auto
Core: 1.43125v
cpu gtl: 63x
cpu pll: 1.5v
fsb term: 1.22v
dram: 2.0v
NB: 1.42v
Sb: Auto
pcie sata: auto
NB Clock Skew: Auto
