*** *** *** Patriot Extreme Performance 4GB (2x2GB) PC3-12800 1600MHz @ £70.99 inc VAT *** *** ***
TPatriot Extreme Performance (EP) Enhanced Latency line is engineered to expand your gaming options. These modules are designed to operate at 1600MHz at 9-9-9-24 timings and are available in 1GB single, 2GB and 4GB kit capacities. It is equipped with Patriot Aluminum Bladed® Heat Shield Technology to improve module stability and performance while operating under extreme overclocking conditions. Engineered with quality and Performance in mind, Patriot Extreme Performance line is the ultimate solution for extreme overclockers, gamers, and PC enthusiasts.
- Extreme Performance PC3-12800 (1600MHz)
- Enhanced Latency (9-9-9-24)
- Patriot Aluminum Bladed® Heat Shield Technology to improve module module stability
- 100% Tested and Verified
- RoHS Compliant
- Tested and compatible with Intel P35, P45, X38 and X48 chipsets
- Lifetime Warranty
Only £70.99 inc VAT.
ORDER NOW
- RoHS Compliant
- Lifetime Warranty
ORDER NOW
