Hi Guys,
Well basically i'm running the PC spec in my signature.
Let's see.
I have windows xp and windows vista dual booted.
Around 2 months ago my PC started playing up. I was gettin the fabled
"Display driver nvlddmkm stopped responding , but has succesfully recovered"
issue under vista.
This started happening so often it drove me crazy.
I went down to basics testing memory.
I discovered one of my sticks of memory to be faulty using windows mem test . I RAM'ed this memory found to be faulty and got a refund due to no stock. I'm still waiting for my new memory.
In the meantime I borrowed a stick of memory from my friend and am running one gig.
I was getting the "display driver not responding" issue more and more, basically I sat there two weeks ago looking at my screen it happened 30 times in 10 minutes.
I did some serious research round the web and GPU issues, including drivers, temperature etc.
MY GPU temp was around 48c on desktop 55c under load (running on a danger den watercooling block).
I phoned BFG tech support, after running every single check under the sun they have decided it's an issue with the card and have RMA'ed the card for me.
I have borrowed a BFG 8800GTX OCd version from my friend(he has an SLI setup), I'm just running the stock fan that's with it.
The temperatutes on this card are around 75c IDLE in windows.
The issue with the "display driver not repsonding" was happening frequent in windows vista and blue screens within minutes on XP.
I decided to reset my default options from my bios. Now My PC wont even boot.
I get the error C1 on my LCD display on my motherboard - which basically related to the memory check status.
I have tried resetting CMOS - no joy.
I think the 1 gig patriot memory I have borrowed from a friend may now be damaged!
The sound from my PC when booting is :
I get a long beep then nothing, long beep then nothing
My main questions are please guys :
What is causing these issues -
- Is it possible I have some crazy PSU issue and it's damaging parts?
- is it possible that i'm just really unlucky and have a collection of different issues i.e.
- faulty memory, faulty cards all seperate issues?
- motherboard damanging parts?
I'm really at a loss now. i'm at my wits end here
Another question is - is there anyway I can tell or test exactly how much power i'm using, surely 620w is enough for one GTX, 3 hard drives, one writer and water cooling pump?
Thanks for reading.
I'm almost at the stage of taking a step back and ordering entirely new parts for extensive testing.
Let's see.
issue under vista.
Thanks for reading.
