PC won't turn on or connect to monitor
5 Dec 2020
My son's PC won't switch on or connect to monitor. When turning on, the fans and lights come on but the power button isn't lighting up and it's not connecting to the monitor at all. It was working fine yesterday. We opened the case this morning to install more RAM but couldn't work out how to do it so just closed it back up again. Since then we've had this issue. Any ideas what could be wrong and how to fix it?
22 Jun 2006
Some cases have wires attached to the panels, so I'd double check nothing got pulled out of place.
OP
5 Dec 2020
Thank you everyone for your help. We finally worked out that where we'd try to remove the RAM, we hadn't pushed it back in properly. All sorted now, new RAM installed and one very happy son Merry Christmas to you all ‍
3 May 2012
Easily done.
