- 27 Apr 2018
Hey all,
I have purchased the following adaptor to use with my Phantek Halos.
https://www.overclockers.co.uk/phan...xNtzCwm7grgjspBxU9iy1FKdlRW47axEaAn6lEALw_wcB
On Phanteks website here it claims compatabillity with "Gigabyte RGB Fusion"
http://phanteks.com/PH-CB_RGB4P.html
My motherboard is a Gigabyte 270X Ultra with a 5 pin RGB header.
The issue is that when I go to plug in the phantek header it is physically too big to plug in to the 4 pins with out bending the 5th.
Is this a common issue or am I missing something? All gigabyte boards will have the same 5 pin header, so is this just not compatible or are we expected to bend the 5th pin?
Thanks
Thanks
