OcUK Staff
- 26 Nov 2014
- Stoke
We're pleased to introduce the new Mini-XL Case from Phanteks.
The Phanteks Mini-XL introduces a new form factor - Super Micro ATX. It offers optimal cooling opportunities with room for up to 14 fans and two 360mm rads. There is also the pretty unique feature of being able to transform the Mini-XL into a dual motherboard system using the optional Mini XL ITX Upgrade Kit.
To give you an idea of the modding potential on this case, here is the Mini-XL disassembled as much as possible without removing rivets
Plenty of potential to customise, and another great case from Phanteks, get your preorders in, stock due early February
Phanteks Mini XL Midi Tower Case - Black @ £144.95 inc VAT
When the Phanteks design team developed the new Enthoo MINI XL, one of their main challenges was how to make effective use of space through design. The MINI XL introduces a new form factor, super micro ATX.
With its unique power supply location, the Mini XL case has been redesigned with optimal cooling in mind. Resembling the Enthoo Primo, it offers extensive water-cooling possibilities and supports the thickest radiators in the market (80mm). The case brings modularity to a new level. Almost every single panel or bracket can be removed or relocated to serve different purposes.
For the ones who desire even more, the Mini XL leaves options for additional upgrades. Perhaps the most interesting one is the possibility to transform the MINI XL into a dual motherboard system.
With the ingenious looks of the Enthoo Primo big tower, the compact Enthoo Mini XL offers a suprising amount of room (up to 14 fans and two triple radiators), and has been developed for mATX- and mITX mainboards alike, providing an unbelievable amount of features.
Features
- "Shifted Design" of the large Enthoo Primo tower
- RGB LED strips with 10 selectable colours
- Sandblasted aluminium at the front and the top
- Internally expandable by optional Phanteks LED strips
- Stealthy: shrouded PSU and drives for neat appearance
- Graphics cards up to 41 cm, CPU coolers up to 21,5 cm
- Up to 14 fans (3x 120 mm preinstalled) and 5 radiators
- Fan hub: up to six 3-pin fans in PWM mode
- Dust filters, pump mounting, cable management and much more
Specifications
- Dimension: 260 mm x 550 mm x 480 mm (W x H x D)- 10,2in x 21,7in x 18,9in
- Form Factor: Super Micro tower
- Material(s): Sandblasted Aluminum, Steel chassis
- Motherboard support: uATX, mITX (optional dual Motherboard support)
- Front I/O: 2x USB 3.0, Mic, Headphone
- Side window: Yes, split-window design
- Expansion slots: 5
- External 5.25”: 3
- Internal 3.5”: 6 (2x 3HDD cages)
- Internal 2.5”: 8 (2x SSD bracket)
- 120mm fan: Front x 2, Top x 3, Rear x 2, Bottom x 3, HDD Cage x 2, Side x 2 (None supplied)
- 140mm fan: Front x 2 (included), Top x 2, Rear x 2 (1 included), Bottom x 2
- 120mm radiator: Front - Up to 240, Top - Up to 360, Rear - Up to 240, Bottom (no SLI) - Up to 360, Side - Up to 240
- 140mm radiator: Front - 140, Top - Up to 280, Rear - Up to 280, Bottom (no SLI) - Up to 280
- Graphic card: 289 mm, without HDD cages 410 mm
- CPU cooler: 215 mm
- Cable management: 30 mm
- Radiator (TOP): 206 mm to motherboard
- Model: PH-ES414M
- Net Weight: 13.8 Kg
- Gross Weight: 15.5 Kg
- Package Dimension: 343 mm x 625mm x 570mm (W x H x D)
- UPC Code: 886523300267
- Color: Satin Black
- Warranty: 5 years
Only £144.95 inc VAT.
PRE-ORDER NOW
Phanteks Enthoo Mini XL ITX Upgrade Kit @ £20.99 inc VAT
The ITX Upgrade Kit for the Mini XL lets you convert from a single to a dual system configuration. This upgrade kit will allow you to have a uATX and ITX system running simultaneously. The package includes one ITX mounting plate, rear plate, and a separate Power/USB drive. The upgrade process is straightforward and easy. ONLY COMPATIBLE WITH THE ENTHOO MINI XL.
Only £20.99 inc VAT.
PRE-ORDER NOW
Phanteks Enthoo Mini 3.5" HDD Bracket @ £5.99 inc VAT
Upgrading storage capacity to your Enthoo cases can now be easier with the HDD brackets. A single slot HDD bracket is available for the Enthoo Series Line to help maximize your storage.
Features
- Model: PH-HDDKT_01
- Dimension: 104 mm x 22 mm x 140 mm (W x H x D) - 4.09in x 0.87in x 0.74in
- Currently Compatible with the Enthoo Mini XL and the Enthoo Primo
Only £5.99 inc VAT.
PRE-ORDER NOW
Features
Specifications
- External 5.25”: 3
- Model: PH-ES414M
- Warranty: 5 years
PRE-ORDER NOW
PRE-ORDER NOW
Features
Only £5.99 inc VAT.
PRE-ORDER NOW
