OcUK Staff
- 26 Nov 2014
- Stoke
We're pleased to launch the brand new Phanteks Evolv ITX Mini-ITX Chassis. This case is based on the absolutely stunning Enthoo Evolv Micro-ATX chassis that was introduced last year, offering many of the features found in the Evolv but in a much smaller form factor.
Big on features and small in size, the Enthoo EVOLV ITX is a budget oriented chassis that uses a metal exterior. The case introduces a new unique bracket solution for mounting a radiator on top and a multifunctional bracket for reservoir, pump, and SSD/HDD.
The Evolv ITX comes with a pre-installed 200mm fan, and is available with or without a side window. There is also support for up to 280mm radiators and 330mm VGA cards.
Stock should arrive around Mid March and will be pretty limited, so get your pre-orders in!
Phanteks Enthoo Evolv ITX Mini-ITX Chassis with Window @ £54.95 inc VAT
Features
- Metal exterior (powder-coated steel)
- Clean and Compact design
- Clean interior - Hidden PSU and HDD’s
- Equipped with Phanteks’ velcro cable ties
- 28mm cable management space
- Additional cable compartment in bottom
- Comes with 1 x Phanteks PH-F200SP 200mm fan
- Supports 212mm PSU
- Supports 330mm VGA Card
- Front I/O: 2x USB 3.0 / Headphone / Mic / Reset
- 1X SSD bracket included
- Offset Radiator Brackets: No conflicts between radiator and memory
Specification
- Dimension: 230 mm x 375 mm x 395 mm (W x H x D) - 9.1 in x 14.8 in x15.6 in
- Form Factor: Mini ITX tower
- Material(s): Steel plates, Plastic, Steel chassis
- Motherboard support: Mini ITX
- Front I/O: 2x USB 3.0, Mic, Headphone, Reset
- Side window: Yes
- Expansion slots: 2
- Internal 3.5”: 2x (1x extra upgrade slot)
- Internal 2.5”: 1x (1x extra upgrade slot)
- Front: 2 x 120mm fan, 2 x 140mm fan, 1 x 200mm fan (included)
- Top: 2 x 120mm fan, 2 x 140mm fan
- Rear: 1 x 120mm fan, 1 x 140mm fan
- Front: Up to 240mm radiator
- Top: Up to 280mm radiator
- Rear: 120/140mm radiator
- Up to 330mm VGA Card
- Up to 200mm CPU Cooler
Only £54.95 inc VAT.
ORDER NOW
Phanteks Enthoo Evolv ITX Mini-ITX Chassis @ £49.99 inc VAT
Features
- FRONT I/O: 2x USB 3.0 / HEADPHONE / MIC / RESET
Specification
- Side window: No
Only £49.99 inc VAT.
ORDER NOW
Features
Specification
- Side window: Yes
ORDER NOW
Features
Specification
- Side window: No
ORDER NOW
