Phanteks nv5
6 Jul 2024
United kingdom
Hi, how do I get the psu shroud led strip to sync with the motherboard argb?
I tried plugging it into the argb hub I'm using and the motherboard and still nothing
I'm running arctic fans using 1 argb header and an argb hub
If it wont work plugged directly into the motherboard its probably only setup to be used with utilising the mode and colour buttons on the I/O panel.
Maybe try contacting Phanteks directly.
