Phone for boss £200ish
13 Jan 2010
Manchester
As title really.
She currently has a Nokia 8 but the baby has broken the screen. So she wants one the same size or smaller.
What would you recommend?
Thanks
That phone only has a 5.3 inch screen it's going to be very hard to find something to match that 6 appears to be around the standard now
A screen replacement would be better option should be fairly cheap
The top and bottom bezzel is big. So it's not actually a small phone as such.
151.5 x 73.7 x 7.9 mm (5.96 x 2.90 x 0.31 in)
So a decent size but yeah it the way things are going now.
Xiaomi mi 9 se
Decent specs
5.97 amoled screen
Under 200
Just been looking at the m8. I did look at the m9 also, but it was over budget? I'll have another look. I think the m8 is to big as it's the same as my Pocophone.
Edit. Just noticed the SE I'll check that out. Thanks
Just watched a review. (Not checked specs or anything) looks a real nice phone.
Xiaomi mi 9 se
Decent specs
5.97 amoled screen
Under 200
Can't find it that cheap? £250 ish. Is it cheaper from China? It was for the Pocophone but I would rather pay the extra if need be.
But then it's going to a £250 phone. So at that is there something else?
Just ordered the mi9 se. Used Quidco and it says 10% cash back via Amazon, so 20 odd quid off if it works.
If it's anything like my Pocophone it should be sweet. I've had it since November 2019 and it's still running sweet with updates still coming in.
