One thing that annoys me with most boards is the position of the 20/24pin power connection on motherboards. It's not a great deal but when using an antec 902 / 1200 and using the option fan mount the loop over affect from connecting the power cable from behind the board does obstruct airflow quite a bit to the ram and cpu cooler.
Just wondering if anyone has heard of any plans to change the connection to a side format like the sata ports as the originals were front facing to begin with?
