Play speakers & headset from onboard sound card?
30 Dec 2004
London
Hey all
I've read that its possible, but only when seperating the front panel from the back panel [i.e; speakers for back panel and headset for front]
however I was wondering if anyone here knows if I can setup my realtek to set 1 out of the 6 connectors on the rear panel to route audio through?
I'm using 3/6 at the moment for my speakers and wondered if the headset can be configured somehow? At the moment I get 0 sound from my headset (not even the same audio stream).
Hope someone can help?
Just connect the audio lead from your case to the motherboards front audio header, then you can connect headset or headphones to the front of the case.
Will have to get a audio header then looks easiest way.
Also, rather than start another thread...
Does anyone know why my sub doesn't work when all devices plugged in? Had it like this for a while now and its starting to bug me!
centre speaker works fine, but the sub doesn't.
I've got the 'colours' matching and the sub works in the realtek when clicked, however in music/films its not 'active'??
